Trailor Help
2
- - Pembroke Pines, Fl.
I have just bought a 1982 oday 192 without a trailor, and I am having trouble finding a trailor that will work. Any suggestions for a new or used trailor would be greatly appreciated.
Dave K.
For a new trailer.....
Since you are in Florida, you could contact Performance Trailers in Clearwater. They make the trailers for the Precision 18, which is a similar size and configuration (shoal keel/centerboard) to the O'days. If looking at used trailers, you'll want one with a gross capacity of 2000lbs or more. A trailer with that capacity will likely have a single axle equipped with 13 inch wheels. For easy launching it should have a dropped axle (spindles above the axle beam) and the cross members should be formed in a shallow V, not straight, so the boat can sit as low as possible. Since there are more used trailers around for powerboats than for sailboats, some adaptation may be required - You will need a center bunk to support the weight of the keel and the side bunks may need to be extended up to reach the hull. But first we should figure out which model O'day you have. Production of the 192 had not yet started in 1982. So, you either have a newer boat that is a 192, or a 1982 O'day 19, the model just previous. If you can post the Hull Identification Number that is molded into the transom, the date of manufacture can be determined from that. Either way, you have a good boat that should provide you with a lot of fun.
H
Hans
Try Triad Trailers in CT.
I have a 192 which I brought used. It came with a triad trailer which is a perfect fit. It pulls with ease behind my Dodge Grand Caravan. http://www.triadtrailers.com/ is the link for the trailers. My onlt negative is that they are expensive.
Tim
Get Galvanized If Possible
If at all possible, I highly recommend you get a galvanized trailer. I got a painted trailer a few years ago when I bought my 192 used. The painted trailer is rusting and needs attention continually. The Load Rite roller trailers will work great with the 192. When I bought mine, I towed it from Indianapolis, IN to Philadelphia and was able to stay at 65 - 70 mph on the interstates towing with a Nissan Pathfinder. Hope this helps.
Jan 30, 2007
2
Load Rite Trailer for a 192
I need to know what model and or size of the Load Rite trailer would work for a 192 ODAY. And any other information that would help me set this trailer up properly. THANKS
