retrieve, Gary
gary, hope that you recieve this, the boat is not easy to center on the trailer, the wieght of the boat as pointed o ut by some one else is supposed to be supported by the keel , we have encountered several short ramps with shorter docks, when you are in deep enough to launch the dock is behind you , so it is not all that fun we are into our 6th year of the process so i was just wanting to make the task easier, the hunter rep said that the bunks were ideal, and rollers not suggested due to thickness of laminate, i have a friend with older oday who usses rollers with no problem mabye i will buy an oday, there should be aneasier way , Mike you can emial me at mmsailor@aol.com
