Trailer Parts
Ben, I lucked out. My slippage was cause by a broken expansion pin. It goes though one of the gears, to hold it in place on the shaft. Home Depot, bolt and nut section. I think it was 75 cents. My jack is made by Fulton. There is one piece I need, that might have to come from Fulton. It is the "tab"(?) that slides in though the jack, at the top, and holds the assembly in place as you crank. I'll see if I can find it from Moe's Link (maybe they changed names) or a Fulton link. MacGregor Corp. may know the answer too. What do you need? I need a new wheel too.
