Trailer for 1976 O'Day 20
Sep 9, 2016
28
ODay 20 Manchester, NH
I find myself needing a new (to me at least) trailer for my O'Day 20. The one I purchased it with is a tandem axle Load Rite that needs extensive work ($2K or so) - the trailer tongue, winch, lights, springs....the list goes on. Does anyone have a recommendation as to what brand or type is best? Also, I found a trailer on Craigslist for a trailer that was previously used on a Catalina 22, that should work shouldn;t it? Any help would be appreciated, thanks.
Mar 20, 2015
3,306
C&C 30 Mk1 Canada
We have an abandoned O'Day 20mat our marina. While the trailer is likely in bad shape I will check to see brand what it is. And take photos.
It is a single axle.
I own a Catalina 22 so I can also do a visual guess on the trailers being somewhat compatible. Likely would need minor modification assuming the keel is the same approximate depth when on the trailer.
Likes: Timm R Oday25
Catalina 310 278 Lyndeborough NH
Are you still looking for a trailer for your O'Day 20?
I have the trailer that my O'Day 19 came on. I converted it for a wing keel Capri-22 with a 8 ft functional extension tongue.
After problems with the original axle, I bought a Timbren Axle-Less Trailer Suspension System w Hubs - 4" Drop Spindle - 5 on 4-1/2 to replace the original axle.
After doing that, I decided to purchase a new trailer Triad trailer custom built for my Capri-22.
So the older trailer with a new suspension is available. I'm only 30 minutes away from you in Lyndeborough NH.
