W
william
i have my h23 blocked-up and am replacing the bunks and carpet on the trailer. one is broken, (the 2x4 wood under the carpet), and murictic acid reeked havoc with the old carpet on both. i marked the posts where they stuck out the bottom of the sleeve so i could get them back in the exact places, (which is kind of a moot point now since i found 2 layers of carpet and probably should raise them a bit higher now). my question is: does anyone have their h23 in the driveway and would be willing to take a measurement to tell my how far your posts that bracket to the bunks extend below the sleeves they slide into. my front ones were flush with the bottom of the sleeve, center extended about 1/2" below the sleeve, and rear maybe 3/4" below the sleeve......real kicker is they are different right and left but aproximately the same idea......fromt posts are flush on both sides but middle and back are a little different....maybe 1/2" each.
