trailer brakes
Meg
Just received a "custom" built trailer from Performance--it came without brakes, yet brakes are required on all boats over 3,000 lbs! A headache I hoped to avoid....
mike epp
surge brakes
best to get surge brakes for a heavier boat. Don't have to worry about disconnecting them when you back into the water. A trailer shop can install them and the previous shop probably should have.
Dan
re:brakes
When I look around, most boats in this size don't have brakes so it appears that the brake laws are not seriously enforced. If you have a big tow vehicle with good brakes and are not towing very far, I'd consider saving the money. I just put brakes on a 15 year old hunter 23 because I was towing it from central Texas to Florida. I like having the brakes for highway driving and when driving in hilly areas but could do without them otherwise. I installed them myself for about $350. I got drums, bearings, galv. brakes, coupler, and brake line (non-stainless) from a local trailer shop for $299. The toughest part to find was a length of flexible brake line to allow the trailer tongue to be extended without disconnecting the brake line. I found a 21' flexible brake line from "A Boat Dock" (I think this is the place) for $34. I did not spend the money on stainless brake lines (big bucks) because the flexible line replaces the main trunk line. So I really only bought the brake line kit for the T-connector, fittings and the brake lines along the axels. There is good info and instructions for installation at www.championtrailers.com.
Meg
thanks
thanks for the brake advice, we are still arguing with the people at Tropic Trailers since they sold this as a "custom-made" trailer. We are a bit thumb-fumbly so the surge brake route might be best for us. We tow from the coast (about 45 miles), and think it wise, even if not overly enforced!
