trailer bearings
rsteig
Aug 13, 2013
9
catalina 22 columbus
I have the standard trail rite trailer for my 75 catalina[5308]. The numbers are worn off the bearings so not sure what size. help?
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
Take the old bearing with you to the parts store... they can measure it and match it up.
Squidd
Sep 26, 2011
890
Find a different parts guy...
kito
Sep 13, 2012
2,011
I bet Walmart has those bearings. Trailer wheel bearings are pretty standard bearings. Take one out, clean it and take it with you to Walmart and match the od, id and width.....bet it fits. Better yet, use a digital caliper to get the measurements and compare. Also, tell that parts guy to go pound sand if he can't measure it for you.
Sep 29, 2012
128
Catalina 22 Clucluz Lake, BC
There is also a small chance that you could have some unusual size bearing that is no longer available or at least very hard to find. I've also got an old (home made) trailer for my '73 Cat and I had to buy all new hubs because we simply could not find bearings that matched the old worn out ones.
hewebb
Oct 8, 2011
329
Catalina Catalina 25 Joe Pool Lake
Find an American Bearing or Berry Bearing facility they will have, or can get, what you need. There could be a bearing supply under another name in your area. Also, go to a trailer parts supply-they may have them. Replace the seals while things are apart.
