Bottom paint
Henry,The toxicity of bottom paint has lead me to use ablative paint. It requires no sanding and wears away as the boat moves through the water preventing buildup. The paint goes dormant when the boat is hauled and can be reactivated by a scrubing with a stiff brush and water before relaunch - providing there is enough paint on the bottom that the boat does not require additional paint. To repaint simply scrub with a stiff brush and water, let dry, and recoat. Ideally, two or three coats should be applied, with each coat lasting a season. In reality, the high wear area will have to be recoated every year (leading edges). I apply two thin coats of ablative and then hit the leading edges again just before launch. Unfortunately, ablative multi season paint is rather expensive. Interlux CSC costs about $130.00 a gallon. There are two options to help manage the cost. 1. Interlux has come out with a single season ablative bottom paint called ACT which is less expensive. They also have a single season water base ablative which is also cheaper but not so readily available. I have used both of these and they are definitely single season paints. I boat in the Chesapeake, where the boat is hauled each season. The ACT was completely worn off of the leading edges and the first couple inches of the water line immediately below the boot stripe. 2. West Marine has an multi season ablative, I believe it is called CCP, which is about $30.00 or $35.00 less expensive then the Interlux. Turns out CCP is made by Interlux (I believe all W. M. antifouling paints are made by Interlux) AND HAS A HIGHER COPPER CONTENT then the Interlux CSC. I have gone to using this W. M. product with quite satisfactory results - AND NO SANDING DUST!PAT
