towing mac 26s with chevy astro
8,480
Hunter 30T Cheney, KS
Which year, engine?
I tow with a 4.0 Aerostar. No problems so far. Both are RWD.
Jul 7, 2004
8,480
Which year, engine?
LJR
Jun 22, 2004
80
Macgregor 26S Dallas, TX
Well,.......not an Astro
I've never pulled with an Astro, but my tow vehicles have been a 96 Explorer with a 4.0 and with a Nissan Xterra with a 4.2 (I think). I pulled my 26S back and forth from Texas to Florida 6 or 7 times. I've pulled the boat all over Texas and would not hesitate to do so again...........except for the gas prices. Depending on how you load up your boat with provisions and extras, you should have no problem. My trailer does not have brakes so I am cautious about putting myself into panic stop possibilities. Corners are no problem if you maintain enough engine to pull through with power AND, as with all trailer pulling, avoid braking in turns. I would feel sure that you have something in your Astro that would compare with my V6s. The rest is primarily just common sense.
LJR
Jun 22, 2004
80
Oct 18, 2007
707
Macgregor 26S Lucama, NC
Not an Astro, but
I pull my 26S with a Ford Ranger, which seems to surprise many people. In fact,when I bought it, I drove to Staten Island and pulled the boat home to North Carolina with the Ranger, and had no problem up to 70 on the Interstate. It wanted to wag a little if I got over 70. Had some difficulty with traction on a very steep slippery boat ramp on Staten Island, but none on the highway, and none on the local ramps. I have a 3.0 litre V-6 with a 5-speed manual transmission. Don't know what your Astro has, but maybe this will give you something to compare to. Where do you sail? I'm about 50 miles east of Raleigh, and I generally go to the coastal sounds or north to Kerr Lake.
Oct 18, 2007
707
Not an Astro, but
walt
Jun 1, 2007
3,535
surge brakes
maybe it also depends on if the surge brakes work or not.. (when I picked up my 26S, the hydraulic res was bone dry..) I think if the surge brakes do work, you could tow with a lighter vehicle. If they dont, a heavier vehicle is probably safer. But I have no idea where you would draw the line..
walt
Jun 1, 2007
3,535
surge brakes
Jun 5, 2004
997
Macgregor 26D Boise
GMC Astro Van
I used mine to pull a large ski boat and to pull a trailer boat. LTD model with 4.3 liter engine and all wheel drive. I launched my boats on lakes that had no ramp- it did very well. No problems towing, but we had the factory towing upgrade including extra transmission cooling. YMMV
Jun 5, 2004
997
Macgregor 26D Boise
GMC Astro Van
Sep 13, 2006
61
Macgregor 26S Advance, NC
THANKS..
Thanks for the info..... I have put a deposit on a 1999 with 95k and ALL the whissels and bells. Earl
Sep 13, 2006
61
THANKS..
Jul 7, 2004
8,480
some suggestions
This isn't a car forum but I'd suggest that after you take possession you do a few things before you tow. The before-purchase ideas may give you some price leverage or allow you to get them fixed per the sale. replace the transmission fluid and filter - make sure it doesn't smell burned before you buy change the engine oil and filter - look for suspicious milky (water) or red (trans fluid) before you buy flush the brake fluid. fluid takes on water after time and lowers the boiling point - a bad thing when you are towing. Check the pad wear before you buy replace the coolant. It wears out over time. Look for rust in the radiator. Also spin the fan if it isn't electric. There should be some resistance if the fan clutch is working Look for unusual tread patterns on the tires to see if you have an alignment issue. It should not vibrate or pull at highway speeds bounce all four corners to be sure the shocks work. It should settle out after 1-2 bounces. Suspension is especially important when towing consider an external transmission cooler if you don't have the tow package. You might ever look into an AirLift system to maintain ride quality when you tow or haul in it
Jul 7, 2004
8,480
some suggestions
C
Chris & Lenore - Mac 26S - Teliki
Hey Justin...
Any idea what the airlift units cost (ballpark)? Thanks, Chris
C
Hey Justin...
Jul 7, 2004
8,480
coil or leaf?
I have coil springs and the kit without a compressor sells for about $80 on the street. I keep a small 12v compressor in the back. I don't know about the leaf spring kit, more probably. There have some additional hardware.
Jul 7, 2004
8,480
coil or leaf?
