Towing a dingy
L
Larry D
I built a Eastport pram from CLC over the winter and have no experience towing behind my 25' sailboat. My situation is that I have an outboard on the stern portside and am not sure how to rig the sailboat or dingy. Any help or thoughts will be appreciated.
Phil Macgregor
Dinghy pic
Here is a pic of dinghy on its leash (painter) in calm conditions.
L
larry d
Towing the pram
Thanks for the response - the info is great. Additional questions? How is the connection made at the pram (single or double point connection)? Does the painter do back to a Y and the Y attaches to the pram? If that makes sense!
L
larry d
Towing dingy
Thanks for the reply - much appreciated! I'll ask you the same question I asked Danny. Does the painter go back to the dingy to a Y and 2 point connect on the dingy? If so, what is your connection at the dingy and how long is the painter (Approx.)?
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
towing
I mounted two stainless steel eye bolts through the front of the pram with large fender washers on back. I doubled the thickness of the wood in this area knowing it would be a stress point. I have a short line between the two eye bolts, maybe 4 feet long, 16 to 18 inches between the eyes. I then attach the painter to the bridle on the pram with a caribener hooked to an eye splice on the painter that I can disconnect when rowing. I don't use a bridle on the sailboat end, I just cleat it off.
DannyS
May 27, 2004
933
painter length
I adjust the painter length depending on the situation. If the wind is really good, I let out quite a bit of line to let the dinghy ride on the downslope of the boat wake, allowing gravity to aid in pulling the dinghy along. In tight quarters around the marina I pull her quite close, sometimes snugging her right up to the back of the mothership so she can't get away and hit the other boats in the marina. In light winds, it doesn't really matter how much or little line you have out. As Phil stated before, in larger waves, the dinghy will surf down the front of the waves and catch up with the mothership. I try and let her ride on the face of the second wave at this point so she can't catch up and hit the our boat.
