I have an Oceanis 390. Aside from NOT towing/bringing the 10' RIB dinghy (which is likely the BEST advice), what technique do you recommend for towing a dinghy 150NM to the Dry Tortugas? Heavy weather SHOULD NOT be a factor--This is our first trip and we will be conservative and choose another destination if weather is not ideal. Specifically, how strong should the weakest link be? What length of line is necessary/smart? Two bridles vs one? Snubbers/shock-ansorbers used? I'd like to keep it cheap, simple, secure, and somewhat redundant, at least for the weaker, more suspect areas. If a block is recommended, what is preferred type?The dinghy has a single attachment point low on centerline--I believe it has a backing plate. It also has 2 lift padeyes at the top of the transom. No other possible tow points exist. All equipment will be removed while towing.Polypropoline line has been recommended since it floats and won't easily be wrapped around the propeller, but it *seems* flimsy. Three-strand has excellent shock-absorbing capabilty...Some say keep it close, some say keep it further out...I'm a little confused by it all. BTW, I purchased a towing bridle for the dinghy. It's rated to over 3 or 4 thousand pounds...Thanks,Clay
