Pendant line reply
Keith, The hole in my board is just large enough for the shackle pin. See if you can get a shorter pin for your shackle. I may have had to do that. I just don't remember. If the hole in your centerboard is too big for your pendant line shackle pin, I would reconstruct the hole with epoxy and re drill it to a smaller diameter hole. I had to reconstruct my centerboard wedges just this afternoon with a 101 West Systems Handy Repair Pack that I had bought in 2001. The stuff is still good too. It set up as hard as a rock in two hours and I was able to reshape the wedges with my dremel tool with the small drum sander. See if you can look up inside the slot with a flash light. Maybe the pipe is protruding too far into the slot from inside the cabin. I know that we have different boats, but I'll take a peek in mine tomorrow if it doesn't rain, and I'll let you know what I see up in the slot. I just received my bottom paint in the mail today so I plan on painting my centerboard and the inside slot as soon as possible. I'm almost certain that I made the braid splice on my pendant line a couple of years ago. They don't use wire cable on the O'Day 25s and 26s anymore. My pendant line looks like 5/16" braid. That's all you need, plus the shackle. The pin on my shackle is just long enough to get the cotter pin inserted when I attach it to the centerboard.Joe
