Hello Fellow Sailors,
We have moved forward with the paint project on S/V Thalassa. We hired the local paint and fiberglass "Guru" who was recommended by our local DIY yard. He seems to know his stuff and is proceeding as per our specs.
One question I am wondering about is methods of smoothing out a hull prior to applying the top coat.
He is wanting to use many layers of primer and then board sand it to achieve the desired result of smoothness. He is also using Awlfair to fill in deep gouges.
My questions are this:
1. Is this method of using what he terms "sacrificial primer" and board sanding a proper technique?
2. And will it turn this into a smooth blemish free paint job?
3. Or should he be following the Awlgrip process of sanding to smoothness, fill gouges and then three coats of primer and then topcoat?
Thank you in advance,
Walt
Walt
