Jim
Has anyone re-routed the topping lift? Mine is original i think. The topping lift is tied to the mast head passes through a small block on the starboard side of the boom then to a cheap little plastic cleat. I have considered putting a small metal cleat on the port side of the boom opposite the small block and attaching a small block to the topping lift then routing a line from the starboard side through the block hanging from the topping lift to the cleat on the port side. Sounds confusing when I write it out like this. I would like to know if anyone has done anything different. I have considered the solid vang or boom kicker but have other projects that need that kinda money.
