Should I do away with Topping Lift?
I've Selden Rodkicker with gas spring. After sail, I would tension the mainsheet against topping lift to firmly hold boom in place. This reduces boom sweeping when boat rocks.
However it means the riggings is under tension.
Would it be better if i let the boom be supported by the rodkicker with mainsheet tighten and remove topping lift?
I'm sure the boom will sweep about more than when topping lift is use, wearing out something like boom-mast swivel assembly?
What do you think?
Thanks.
Ken
What do you think?
Thanks.
Ken
