You could also use a Clamcleat attached to a line to cleat off your topping lift. This way, it wouldn't be connected to your boom, but would still allow adjustable height, which is desirable for light wind so that the topping lift can take the weight of the boom, and therefore not over-tension the leech, allowing for proper twist at the top of the main.
http://www.clamcleat.com/cleats/cleats.asp?theid=8
Personally, I would rather have slab reefing than boom roller reefing. Roll reefing around the boom leads to poor sail shape, and requires you to put something in the sail to attempt to accommodate the extra material of the sail's draft. Also, as soon as you roll up the sail, you've got no place to connect the vang, unless you have a reefing claw vang, or use a panel of fabric to roll up in the sail, and attach the vang to.
Admittedly, I have never used boom roller reefing, but it sure sounds more fiddly than slab reefing. I can reef my slab reefed sail (often called jiffy reefing) in less than a minute. I guarantee it would take me longer to try and get good sail shape with roller reefing.
Brian
