Does any one know the lenght of the single furler line or the topping lift line for a 1990 H30? Also how do you route the topping lift through the boom and mast?Thanks,John
Replaced topping lift on my 30T (1991) several years ago but I did not record the length of the line. Sorry about that. But, running the new line into place was a cinch. I taped the new line to the old line and just pulled it through the mast. Just made sure the tape connection was not too large to easily pull through everything.
I did the same thing on my '92 30T, changed out the topping lift, but didn't record the lenght. I know the mast hight is 50 or so feet above water line, but I don't know the sail angle measurement.The info my be in your owners manual or available on this website in Boat Info. You can tape the distance from the base of the mast back to the cocpit, if it's run back there.
