I have a 2000 H340 with the B&R Rig. The main sheet works from a traveler mounted on the cockpit arch. The boom is supported by a topping lift that runs from the mast-head. In our slip or at anchor, the topping lift vibrates in the wind and even picks up the vibrations of the propellers of passing boats. If I ease the topping lift or the main sheet, the blocks on the main sheet wear back and forth on my bimini. If I let the boom rest on the arch, it clunks around and still rubs on the bimini. The topping lift is eleven years old at this point and must be stretched to its maximum.
Any advice to stop the vibration and/or the noise.
