I would very much like to know if other Hunter 430 owners have a problem raising the mainsail. I have to keep the sail to starboard in order not to catch the batten in the topping lift line. It catches about two-thirds of the way up. I also have a problem with the electric winch - it cuts out periodically and can only be used in pulses. I had a mechanic "repair" the problem by installing a new winch motor at great expense but the only difference with the new motor is that thought it still cuts out it will eventually get the sail up. Any thoughts?
