Don,
Have you had occasion to use the topping lift in light air sailing? It seems there are several theories about how to best shape the mainsail to take advantage of light air (under 5 mph). First I hear 'loosen the chord of the sail, make it baggier to get more lift. Then I hear 'tighten the chord since light air will detach more easily and needs the tighter chord to stay attached.' Now I am in a discussion that claims the topping lift can be used to increase twist so that light air can be engaged at the top of the sail. I usually think of using twist to dump air to keep the boat on it's feet.
"You set the twist or lack of twist with the lift and the mainsheet will control the boom angle to the centerline of the boat. I used it without the 3:1 block for a while but wanted to be able to lift the boom up against the tight mainsheet with a little more force at times. As you tension them against each other the boom moves toward the centerline of the boat. without pulling the twist out of the leach." by Bob (without permission)
I find light air sailing demands close attention to many things and there are variables that each size of boat need to pay more or less attention too. So one answer never seems to work as well for everyone. :neutral:
