Top Deck Paint
6
lancer powersailer lake texoma
I have a 1985 lancer powersailer that is in great shape...but needs top deck refinishing. I have had quotes of 15k. I plan to use this boat for just about 3-5 years as an introductory to sailing (I am a newbie). There are no major problems with the deck except some surface cracks and discoloration. Is there a good sealing paint and method for a do-it-yourself job that will satisfy the short timeline and not cost me so much money?
May 17, 2010
4
balboa 1970 cherokee
If it's fiberglass, you can use arcrylic latex (or so I have read) I used an oilbased impliment paint avalible at wal-mart or tractor supply for less then $30 a gallon. I did not paint the non-slip treads for fear of making them too slick. It's all about prep work. after cleaning real good, and after a light sanding, wipe it down with gas or a good thinner, you want absolutly no oily residue left on it when the paint goes on. I would suggest for best look, thin the paint (agian I use gas) and apply with several coats. However, if you have any bad cracks or deep gouges you 'ought to fill these first - work the edges of the crack first and put a good sanding there (but not to gouge it out) then fill it.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Deck Paint
Home Depot and Lowes have a Urethane porch and deck enamel that should do a good job. It is also less then 30 bucks a gallon. You can also buy anti skid beads that you mix with the paint. 15K sounds totally ridiculous, for deck painting. I have a friend who had a Hunter 30 done. He had the bottom, hull, decks, and a new roller furler installed. I think the total was around 14K.
Jan 10, 2009
8
Hunter 33 MONCTON
Interlux Brightside is a excellant product. I did my Deck last year and it gave amazing results. It's a apllied with either a foam roller or Brush and then tipped (read directions). The paint here in Canada is around $100 a gal and it is worth every cent. You must lightly sand between coats.
Mike
May 18, 2010
6
Thanks!
2,288
C30 Event Horizon Port Aransas
Lancer-a-lot
If you want to do it the best way. I would refinish your gelcote with a power buffer and a step by step preogression of polish from corse to fine. You can restore it to look new and it will be more valuble when you sell it. There is a guy on this forum who has a system down and can tell you exactly what to buy and exactly how to do it.
This link is from the archives here. http://forums.sbo.sailboatowners.com/showthread.php?p=557970&highlight=polishing
If your gelcote is really not that bad there are other easier,but less perfect ways of 'polishing' it, like polyglo or island girl.
This topic has been gone over so many times, sometimes we get lazy with our responses.
