Don't be too hasty to reduce rake
I had the same problem when I bought my H23 three years ago. I reduced the rake by half and ended up with more weather helm. After two years of experimenting, I eventually found that mast rake was not the main source of my weather helm...excessive heel and poor sail trim were.Excessive heel can be reduced by putting more weight on the windward side of the boat, and also by good sail trim. Conventional wisdom says that 15 degrees of heel is about right for most trailerable Hunters. A clinometer will help here. As a general rule, I try to keep the leeward rail at least a foot off the water.Poor sail trim is trickier to fix, but it's easy if you remember that weather helm is caused by a mainsail that is too powerful relative to the headsail (jib). Since most Hunters have powerful mains and smaller jibs, the solution may be as easy as going from a 110 working jib to a 130 genoa. Otherwise, you have to find ways to depower the main. Here are a couple of ways to do it when sailing upwind, in order of relative ease:1) increase outhaul tension and cunningham tension2) reduce leech tension. In most cases, this is done by easing the mainsheet slightly. When sailing close-hauled, the mainsheet also pulls the boom DOWN, which tightens the leech. Leech tension is correct when the top batten is parallel to the boom. In heavier air, it should point off to leeward. This means the leech is open, spilling air off the top of the sail and reducing heel. Another way to reduce leech tension is to tighten the backstay. This bends the mast, which depowers the sail in two ways at the same time; flattens the mainsail and reduces leech tension.3) in heavy air, ease the mainsheet in the gusts and retrim as the gust passes. It's a pain when cruising, but very effective when racing. If you have a traveler, ease that instead of the mainsheet for even more effect.4) tune some bend into the rig. Adjust the mast to the rake you want using the forestay and backstay, then tension the upper shrouds to give you the prebend you need. Make sure the mast is centered from side to side. Finally, tension the lowers shrouds to stiffen up the rig.The amount of rake and prebend depends on how aggresively you sail, the typical winds you encounter and the condition of your mainsail. If the main is old and blown out, you'll probably need more prebend to flatten it.Sorry to be so long-winded, but I wanted to be as thorough as I could. Check the archives also, I think we've had several discussions about this in the past. Good luck.PeterH23 "Raven"
