G
Guest
with only three cleats, one bow and two on the rear, I am finding it hard to tie the boat up at dock. I am on the intercoastal in florida and the waves bouncing from side to side are pretty brutal.. in the north, I've always had floating docks in fairly protected harbors.. Plus they say for hurricane season to double line with at least 3/8in rope and there is no way I can fit two of those on the back cleats.. Wondering if anyone has used anything different? attaching cleats to the toerail - good idea - bad idea? I've seen ones that can be bolted on to the toerail or could I use some snap loops over toe rail? would many smaller (cheaper?) lines with snap loops at the end be more effective, provide more loading more evenly on the toe rail?I would think that with the jib sheets being hooked to the toe rail that it would be pretty strong. I would use the winches but the waves coming in off the intercoastal roll the boat over 15-20 degrees then back over to the other side, I really don't like the idea of that much jerking on the winches. Right now, I have two 40 foot ropes on each side stretched front to back in an X pattern.. which seems to be doing a pretty good job at controlling the rolls and adjusting to the tide swings. Hurricane season is what really worries me. any suggestions?ps. at least it isn't a powerboat, about one a month sinks because of waves breaking over the sides. thanks!R Paquin
