I have a Blue Sea Systems panel with 30+ circuit breakers (it is a live-aboard sailboat, lots of pumps and electronics). I have 2/0 gauge cables running from the battery banks to the panel, and a mix of 2ga 4ga, 6ga, and 10ga wires connecting pumps, electronics, etc. to the individual circuit breakers. It is a mess of large wires in there, making it difficult to work behind the panel, and the large gauge wires are stiff enough to put pressure on the circuit breaker terminals (one circuit breaker already broke because of this).
The question is: can I use step-down connectors on the large gauge wires before the wires enter the circuit breaker panel so that all the wires entering the circuit breaker panel are 10ga?
For example, a 2ga wire is used for the macerating toilet. Can I use a step-down connector to change the toilet wire from 2ga to 10ga right before it enters the panel? That would make the toilet wire around 21 feet of 2ga wire with the final 2 feet of it being 10ga wire before it enters the panel.
Can this be done, and could it cause any problems? Or is this what people have been doing all along?
Thank you.
Thank you.
