Hey everybody. First time trying to pump the toilet this spring on my '92 Hunter 27 after the below freezing winter here in Kentucky, and I'm having a problem with the switch that gets you from 'wet bowl' to 'dry bowl.' With the switch in wet bowl position (left) the toilet fills up with lake water when pumped like it's always done before. But when the switch is moved over into the evacuate position labeled dry bowl (to the right), when pumped the toilet only continues to fill up with water. What I noticed is that when I try to push the switch over to the right into the dry bowl position it doesn't fully seat; my impression is that something internally is stopping it. If memory serves me correctly before the switch would move all the way to the right until it was stopped by the light colored switch casing. Here it is after moving it as far into the dry bowl position as it will go, which is about 3/8" short of it's previous movement...
So I'm all ears as to what you guys think might be causing this. I'm hoping something has made it's way into the tubing and is stopping the switch from completing it's travel. This would probably be the simplest fix. But as I've never seen this before I thought I should ask around before I dove into anything.
Thanks for the help.
