Dave, The most important question is what size
and weight boat will you be pushing with this motor. By going with a 4 stroke or 4 cycle engine (both being the same)you will greatly reduce the amount of pollution you put in the air. A 4 cycle engine is also different in how it arrives at its horsepower ratings.While the engine weight, cubic inch, or cubic centimeter size is the same for all horsepower ratings, the differences are gained by changes in camshaft lift, duration, overlap and timing. Compression differences and carburation or fuel injection changes also have major input values. Horsepower ratings are most often gained at higher RPM ranges. Horsepower is the push that gives top speed.Torque is the value that can move a mass of weight off a dead resting position and into higher speeds. Torque originates at low RPM values.As you stated this same engine comes in ratings of 4,5 and 6 HP. The higher the HP, the greater the loss of comfort. Higher HP reduces smooth idle and fuel economy. It usually required more maintanance and always costs more. Sometimes fuel economy so greatly reduces range as to be unuseable.If you are pushing a light boat then higher HP engines are great. If you are planning to move heavy displacement boat then what is required is a high torque engine. Therefore to push your dingy, and since the motor weight is the same regardles of HP I would go for the larger HP engine. To push a heavy boat I would look for a motor with the higher torque value. Then try this motor and see how close it comes to pushing the boat at hull speed. Also study RPM ranges closely. If the engine pushes hard but the RPM range will only come to about 70% of its rated range then re-prop with a more powerful prop rather than higher speed prop. This should not only raise RPM but also speed. If the motor being used also generates power to recharge the batteries then you want the highest RPM while still running in a good torque range. Most engine dealers will explain these factors to you and also supply the props necessary to find the right range.So,I know I've confused you because I'm also lost. That's why "Speedy" has a pair of nice paddles, one for each of my wifes arms.RayS/V Speedy
