C
Crazy Dave Condon
Toahtsu which also builds the Nissan engines has pretty much done away with the two stroke engines except for the 3.5. I am not sure if the 2. 5 is offered anymore. The 9.9 has been discontinued but the 9.8 four stroke with three blade prop is going to be a good engine. There is a problem trying to attach cables to the motor as there is no cable hook up kit formely known as the SRC cable attachement kit if your are planning to run cables to the pedestal for pedestal control of the throttle and gear selection. If I come up with a fix then you guys will be informed. Remeber that you cannot do that with a tiller style Honda on any engine after 2000 model.so long fair well I am going to outer space
