I have a Mercury (Tohatsu clone) that has an annoying carb problem. For background, I have had this engine for ten years. I had a Tohatsu twin of this for another ten years. It was a one-pull start engine. This one was one of the last two strokes sold by WM in CA. As such, it is a CARB certified engine that runs so lean I finally figured out I had to choke it even when it was still warm and had to run 50% choke for the first 30 seconds or so of acceleration when cold started to warm it up enough.
It sounds like I hate it but I don't. To the contrary, it is light, compact and reliable and had plenty of torque for our needs.
However, with the gasoline formulation changes in the past couple of years, it has become a PITA. Mostly, it's due to the fuel going stale in less than six weeks. Now I always put fresh fuel in it before a trip, add Stabil always and run the carb dry before storing. This after several carb overhauls. Now my problem is that the float valve hangs up upon fresh use and the carb bowl overflows and the engine floods. Happened too many times to be a piece of debris. Once torn apart and freed, all is well for the duration.
It isn't complicated, but I cannot figure out why it does it after a run-dry. Or, what to do about it.
Any ideas most appreciated.
