Went out for a sail today and while motoring out, my three year old Tohatsu 6 Sailpro abruptly quit running. It restarted but would bog under load and died several times as we limped back into the marina. Water cooling discharge was fine with no overheating.
Hadn't run the engine in about three weeks before then, and the gas in the tank is about two months old, so perhaps there was moisture or other contaminants in there - I do add Sea Foam after every fill.
Back at the slip, I checked to make sure the spark plug wasn't fouled, was properly gapped, and was secure. The fuel filter, which I changed at the beginning of the season, looked clear, and the fuel lines showed no sign of leaking. Shook the gas tank to mix the gas a little and then while at the dock with lines secure, ran the engine again - started right up and idled fine for several minutes. Put into gear and powered up and it again bogged down, lost power, and quit. Seems like fuel starvation to me. After quitting, it will start again after two or three pulls.
So, my plan now is to drain the fuel tank, check the fuel tank pick up line for clogging, and try new gas. After that, I'm thinking the air filter, fuel lines, and carburetor is next in line for troubleshooting.
Just thought I'd throw this out there to see if anyone else had this issue with their Tohatsu 6 Sailpro and if so, what they found.
Thanks in advance for any help.
