29.5 midship cleats and bow cleats
I added bow cleats in addition to the 2 already in the anchor locker. Not a big job. However make sure to use sturdy backing. I think I used a strip of 3/8" stainless about 2" longer than the cleats I installed. The cleats are well sealed and tight to the decking. I still use the cleats in the anchor locker for the bow lines and use the deck bow cleats for the spring lines.For a midship cleat, I was going to install them by the stantions midship. Figured it was a bit of a hassle. So I put on the portable sliding cleats on the jib sheet tracks. They work fine for docking puposes. However, I don't leave the boat tied up to these cleats. They are probably OK, but I don't think the track is designed for this type of wear over a long period on time. Like I said, it is great for docking purposes - but then I tie off with the more permanent cleats.
