I'm getting tired of continuously cleaning my fresly waxed topsides because of water stains coming from the toe rail drain holes on my Beneteau 430 Oceanis. Anyone have a solution? Thanks.
Do you know what's causing it? If it's gray or charcoal color it's probably from dirty air, in which case that's a tough one. If you're located anywhere under the flight path for jet aircraft or downwind from an arterial or freeway that's probably the source. Or maybe downwind from a coal or heating oil emiter.Are the other boats in the marina having similar problems?
