Leaking Toe rails
The problem isn't as simple as an occaisonal leaking toe rail bolt. The sides of the hull rise up and turn flat. The edge of the deck lies on top of the flat part of the hull and is held together temporarily by common screws until the toe rail can be bolted on top of the joint with the stainless bolts. Before fastening the toe rail to the boat, a "butyl tape" was laid on the seam by the builders and squished down onto the seam by the toe rail. The idea of the tape was to form a water-proof gasket to prevent water from working its way under the rail and into the boat. Over the years, the "tape" turns to goo and moves around- from the flexing of the boat, I guess- and voids occur in the seal between the toe rail and the hull. The entering water is most noticeable at the rear of the boat where water stands and can not drain off. I tried the old "tightening the screws" trick. It doesn't work. Just caulking the screws won't keep the water from entering at the joint between the hull and the deck. Two years ago, we removed the toe rails and squished a mess of polysulfide adhesive/caulk onto the seam and replaced the rails. That lasted a year. I am now looking for a proper, long lasting material to use as a gasket in place of the short-lived butyl tape. I haven't found it yet. I didn't use 3M 5200 because I figured if it still leaked after the repairs were made, I'd never get the sucker off again.
