To Pearson 303 owners
Mar 21, 2022
133
Bristol Corsair Tampa
Hello
Im way away from my boat and need a some numbers... Distance between safety line and deck(im planningbto send for safety netting and need such numbets plus any other advice you might have regarfing this... Also the marina has been inside the boat twice and after findingvthe bilge full and emptying such is full again... Any ideas fromvwhere she might be takingvwater in the bilge?
As always, much oblige too all.
CRivera
Aug 19, 2019
9
Pearson 303 Marion
On our Pearson 303, the main culprit was the Bimini mounts near the front of the stern rail. The deck is shaped to drain through some scuppers just forward of that. But instead of draining into that and through the transom, it was draining through the Bimini mounting holes and into the bilge! See if you have something similar, since that's where the water collects.
