During my most recent work on Salacia the old non-functioning Lectra-San system has been completely removed and replaced with a fully manual Levac set up with holding tank/ Y-valve set up. Now being removed are the 10 gal. hot water heater and the electric pumps for both fresh and saltwater systems, the pressured systems to be replaced with foot pumps. I am going to be using an Aries wind-vane for breezy days and plan to attach a tiller pilot to the wind-vane for not so breezy days (this is an option to a more expensive/more power hungry auto-pilot I hear). As I see it...my 2 remaining big drains on my house batteries will be my older radar, which I may replace before it breaks with the newer broadband radar if I find a buyer for present system, and my refrigeration.
Now for my question......Currently I have a wind generator (30 amps) and 120 watt solar panel ( with less than perfect set-up...mounted fixed flat right between radar array and wind gen on tower on aft deck) , fridge compressor draws 28 amps I believe maybe a bit more and is spec to run 18% of the time at 86 F ambient temp. Cold box currently keeps 18 lb. bag of ice for over 5 days so I believe it to be well insulated. I REALLY want a good working fridge....but will I be able to run continuously while at anchor and under sail w/o having to use engine or portable gen I carry for A/C? Thanks!
