To furl or not to furl...
K
Kai
After my previous post got so many good responses, maybe I may ask another question: I hear conflicting comments regarding the roller furling. I understand the issue of mast-raising with and without the furler, so thats mainly a convenience issue. But what about this: The 26 M does not have backstays. Therefore, it is in question how much and how easy you can apply tension to the headstay. I would think that you need nice headstay tension to use the furler. What is your experience with this situation?? Is there a requirement to increase the stay-tension on the rigg, possibly by using special (lower stretch) stays? Your comments are all highly appreciated! Regards, Kai
Richard
get the furler
the spars and standing rigging is angled slightly aft. Plenty of tension. Yes it takes a lot more tugging with a ratcheting load tightener to get the shackle pin in, but You can roll up your genny or jib from the cockpit. This is a decently large boat. If your single handed sailing, and facing a squall, you don't want to run up to the foredeck, while leaving the helm. Additionally you can leave a little triangle of foresail out, to give you much more control in a storm. Roller furling is a big plus.
