Tjhe proper pressure for cap on expansion tank
Bob Tigar
My Perkins 4108 has a 7 lb cap on the expansion tank. I know that the pressure in the tank affects the point that the coolant boils. 1. What is the formula to determine the effect a higher pressure cap has? 2. Why would one use a higher/lower pressure cap? 3. Is this the right pressure cap to use on this engine? Bob
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
My Westerbeke 30
AKA 4/91 requires a 4 lb cap.
7,737
Alden 50 Sarasota, Florida
ideal gas law
The formula is PV = nRT and you can do a search on "ideal gas law" to define the parameters Pressure is directly proportional to temperature; as one goes up, so does the other.
