My boss is on vacation thru today, so I escaped from work early to work on the boat. Taking the cover off early in hopes of an early launch...which didn't happen...resulted in dirty decks I had to scrub on my hands and knees. Then I washed the topsides and scrubbed off some black marks. While the topsides dried I flushed the coolant out of the engine. Then I put two coats of poliglow on the topsides. I am BEAT.
I am also bummed that somehow I apparently forgot to secure the jib halyard when I removed the winter cover. It secured itself to a shroud, which wasn't a problem...the problem is that it beat against the mast for two months removing quite a bit of anodizing at the top of the mast. The yard contract says to secure noisy halyards or they will and will charge me for it...this is a case in which I would have been happy to pay if they had done so. Yard is really slipping. I notified them the the guy next to me had ties his tarps to his jackstands...a big no-no. They did take care of it, but they obviously don't walk the yard much.
