On the 49 /50, there are wonderful transom lockers which give great access to steering, plus massive amount of storage.
I have crawled into this space dozens of times. As well, on the foredeck, there is a substantial sail locker, which I have also lowered my body into several times a season.
In both of these lockers, every time I get out, I'm bleeding either on my arms or legs, (or both)
When Hunter installed the Bowmar hatches, they used self tapping screws, leaving many pointy bits on the inside of the hatches.
Every season I swear I'm going to fix this, but never do.
Well, I finally had enough of the self -mutilation.
The fix was easy.
Load a Philips bit into the drill.
In reverse, just wind them all out.
Then, chuck in a 5/32 bit, and run it through all the holes.
Then, set the drill clutch to a low setting.
Put a 10-24 tap in the drill, and carefully speed tap all the holes.
Get a bag full of 10-24 flat head machine screws 3/4" long.
Run the entire thread into the neck of a tube of 4200, liberally coating it.
Then, chuck the drill with a screwdriver bit, and drive in all the screws.
There should be about 1/4" thread exposed.
Then load on acorn nuts, and twist them tight.
Entire time frame to fix both stern and sail store hatch.
2 hours.
Why did I wait so long???? Must have enjoyed the pain I guess
The fix was easy.
2 hours.
