Tire size & boat weight, 26S
walt
Jun 1, 2007
3,546
Regarding the adapters, I measured my hub and rim inside diameter and the link I provided earlier did not have the adapter I needed. I tried some other numbers and finally found that a set of four is about $55 but the ones they provide are plastic.
My only expertise in trailers is having lot of trouble with them over the years.. but it seems that while you probably dont "need" the wheel hole to fit snug on the hub, it probably does decrease the odd's of losing a tire on the road - and Im all for anything which will decrease the odds since Im only going to have two tires on the trailer for a while. But a plastic spacer would probably deform so fast that its only purpose would be to center the tire when you are installing it - ie, no use for the problem Im trying to solve.
Im also probably going to replace the hubs at some point so for now, Im just going to have the lug wrench handy and check/tighten the bolts at least every time I get gas.
Blake
Apr 20, 2008
137
Macgregor 26S Red Lodge
Walt, on my last post I made an error concerning center hole size. The diameter of the wheels that the PO purchased for my original Mac trailer was 3.25, not 3.5. I only used these tires for about 800 miles, but had no problems on our trip back from Seattle. These were after market trailer rims purchased from a Les Schwab dealership specifically for the trailer. I think Sumner has the right idea. Check the lugs and hubs often and have fun.
