Mac trailer
A bit of information, just my own knowledge, I'm not an expert, just passing on a few things I've learned over the years, I'm sure Sumner can provide a lot more information on the rims issues than I can. Others may have their own experience thay can contribute.
Regarding my costs for the two axle conversion, it was about $300 for the new axle with hubs, the double axle linkage kit, two new leaf springs, two fenders, and a bit of steel to connect it all together. The s/s disc brake kit was about $450 all by itself. I still need to buy two new tires and rims, I'm running the two originals and two new ones at this point.
Sumner if you want to put up any of the pictures I sent you of my trailer conversion go right ahead. I'll try and get some better shots in a few weeks. I'm leaving to drive back to Canada tomorrow morning from Florida, so if you can wait a bit you will have some better shots to use.
The 3200 lbs rating I specified for the trailer axle capacity comes from a set of MacGregor factory blueprints I have for the trailer used on the 26S, it is constructed with 4" channel frames and is the trailer I own. It appears that the trailers built until 1992 were made with 4" channel frames, the trailers after that were 3" channel, the later ones seem to be even more flexible, I do not know what these were rated to carry. I suspect the X & M trailer have a higher weight rating because of the bigger motor, they seem to have much bigger springs looking at them in a marina parking lot. Usually a trailer has a plate on the side near the front that lists the carrying capacity, mine was long gone by the time I bought my boat. It would be interesting to see what some of them say, can any one help out here ?
Another thing to be careful with on your trailer. The axle can have a small pin hole in it, if it gets salt water inside the axle it will rust away from the inside out. It will look fine until it fails. A fellow from a trailer shop in Florida told me they sometimes see axles fail near the spring u-bolts because they are too thin from rust inside the axle, that seems to be the only explanation.
The Mac trailer uses a wheel with a 4.5" bolt hole circle but you must also be careful of the correct wheel width (5.5") and offset. Too much offset and your bearing will have a much shorter life, too little and the wheel can fowl the barke caliper or drum. If the wheel is wider the offset will have to be all outboard. The wheel needs to have the correct hole in the center, I would not enlarge it to fit, some of the trailer weight should be carried on that area around the hub. A portion of the face of a steel wheels is proud of the hub until it is pulled in tight by the wheel nuts, if this does not happen the wheel nuts will not stay tight. Try to get the correct wheels for the trailer.
I may be offline for a few days while I'm on the road, Bob
