Rigging Tips
Here area few tips that have now been tested and I whole heartedly recommend to all H-170 owners.1) Replace the roller furling pins with Ball Lok Quick release pins, 1" x 1/4". I replaced both the upper and lower. At 20 bucks a crack, tie a lanyard to these and secure to the roller furling so you don't drop them into the bottom of the deep blue!!!2) As John listed above, replace the gooseneck pin with a 1 1/4" x 1/4" Ball Lok Quick Release pin. A 1" pin was about 1/16" too short to work. The 1 1/4" is a bit long, but it is the next size in length. Cost is $20. Don't forget the lanyard!3) My biggest recommendation to trailer sailors. Pull off the 4 chain plates on the shrouds and throw them away right now!!! I mean it ...right now!!!! Replace them with 4 Johnson Marine lever type shroud adjusters, small size, Johnson part number 15-212(see link below). Secure them to the boat with 4 Ball Lok Quick Relase pins, 3/4" by 1/4". Mount them so that the upper and lower shroud adjusters open opposite one another...uppers should open forward and the lowers should open rearward. Cost is about $23 per adjuster and $20 per pin. This is a $160 upgrade ($200 if the Roller Furling is also dealt with), but after rigging the boat once with this setup, as well as the change to the Roller Furling, I noticed that the time is GREATLY reduced and MUCH easier as you no longer have to fight with any of the tensions. Open all the adjusters. Attach the Lowers to the hull mounting bracket with a Ball Lok pin. Lift the mast. Secure with the Main halyard tied off to a bow cleat. Slide the Ball Lok pin into the roller furling securing the jib. Attach the Uppers to the hull mounting bracket with Bal Loks. Squeeze the adjusters closed (which tensions the shrouds)and lock the adjusters closed with the included fast pin. Release the main halyard. Thats it! Time 2 minutes!!! What more can I say. I don't want to hear from others that the screw type adjusters give better tensioning control (they do) because this is not about making fine adjustments... this is about rigging ease. I have calibrated screw type adjusters on my racing scow and all they lead to is the temptation to make constant adjustments that do nothing but screw up the skipper and crew. If you talk with the majority of scow racers (or any boat racer) they will agree. Factory and sponsored teams have all the neat stuff because they can afford it! Use the Levers and ignore the calibrated screws. Do not forget to tie a lanyard to both pins on each shroud adjuster and secure in the lanyard hole on the adjuster.4) Lastly, not really a rigging issue, but add a Clamcleat CL 257 Quick Release cleat to the tiller to affix the rudder downhaul to. I left the original Clamcleat on the tiller and use that for the uphaul. I have them mounted opposite of each other. Cost is about $25.I am running out of time but have made several other minor changes to my boat which we can discuss later. I am looking forward to other's ideas.If you haven't noticed, I love to tinker with this stuff!!!Godspeed,Rusty (or sometimes RJS)
