Sometimes Worse than Singlehandling
Gary, This reply is a variation on the singlehandling theme, which is handling the sailing while the first mate reclines against whichever bulkhead happens to be on the high side or in the shade of the dodger. This make the mainsheet traveler lines inaccessable without risking decapitation of the relaxing first mate. My fix to this over the winter to be tested within the next 2 weeks is to bypass the cam cleat and route the control lines around the hand rails through a fairlead on a dodger upright to a block/cam cleat combo back at the stern rail. I also use the same type of block/cam cleat combo on a swivel for the reefing line because it's easier to keep proper tension on the sheet while cleating the furling line, than wrapping it around the standard horn cleat. As for the mainsheet to the helm - on my c28 (good picture on this site) I used to have it loosely led to a cam cleat on the pedistal, which being a small, but strong guy worked ok, but on the c320 it almost jerked me across the cockpit - I have to go forward and use whichever winch that the first mate is not blocking (double ended mainsheets are Great !). I have also replaced the standard genoa lead cars with the Garhourer adjustable leads so I can adjust them from the helm instead of sending the reluctant first mate forward to move them - which is guesswork with no load, and impossible with load on them. I also added a foam luff pad to help keep a good shape on the genoa because I partially furl a lot just to be able to see under the genoa to dodge lobster pots without having to crawl all over the cockpit as the only forward looker. Maybe the firstmate/major financeer will agree to an Autohelm this year which will complete her relaxation/enjoyment of sailing.Stan"Christy Leigh"c320 #656
