Timidly rebedding stanchions
Nov 10, 2022
4
Hunter 260 Eastern Bay
I know there are a number of posts about rebedding stanchions, so apologies if my questions are repeated somewhere within the archive. I see that most advice mentions bolts and backing plates, but it seems that the Hunter 260 (2003) does not have a backing plate but instead used machine screws into the fiberglass. The back of one screw is accessible from a cabin access panel but not the other, nor the top screws. I worry that if i remove the screws, I will never get a strong seating if i reuse the same hole with butyl tape. I dont have much experience with butyl tape in a case where I would need it to not just seal, but ensure a strong grip between a machine screw and a reused fiberglass hole.
Does anyone have experience with this? Will the tape seal the hole and give enough structure to bring it back to full strength? Is there another sealant I should use instead?
Or is the only option to redrill and use a bolt with a backing plate? This is, by far, the worst option since I would have to cut multiple sections of the cabin to access the backside of the bolt.
Thanks in advance for any words of wisdom.
Jan 7, 2011
5,884
Oday 322 East Chicago, IN
I doubt that the stanchion bases are just held on with a screw into fiberglass…machine screws tells me that there is an aluminum plate embedded in the fiberglass, threaded to accept your machine screws.
Butyl tape does not harden, and certainly would not provide any “grip” for the threads on the screws.
I would rebed one, using the same holes and machine screws, and give it a test…not so hard to break anything, but to satisfy yourself that the screws are tight in the deck (meaning threaded into something substantial).
I had a Hunter 270. Nice boat.
Greg
A dab of JB weld in the hole will hold it for sure.... but you will never get that screw out again.
Oct 6, 2007
1,165
Hunter H30 1982 Chicago IL
Greg
I agree. The presence of machine screws tells me there are threaded aluminum imbed plates in the fiberglass deck. Not unusual for Hunter. I have them in multiple locations on the deck of my ’82 H30.
Butyl is the right sealant to use.
Kermit
Jul 31, 2010
5,721
Nov 10, 2022
4
Thank you all for your advice, I'll be trying my hand with the rebedding process later this week. Still nervous about breaking "the seal" but feeling more confident it wont turn into a "screwing through drywall" situation.
One follow up (because i havent really done much with aluminium), when reseating a machine screw in an AL plate, would you suggest a tourque wrench or an upper limit on the tourque of the drill to avoid stripping? Or maybe AL is just more robust than I give it credit. I have this vision of driving deck screws into butter that I cannot shake.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Forgot to mention it, but use some Tef-Gel or other anti-seize lubricant on the threads. You will be mating dissimilar metals (stainless screws and aluminum plate) in a salt environment, so it will "gall" or seize up over time. The lubricant prevents this. Yes, it is ridiculously expensive for "some grease", but it will allow the screw to be removed in another three years.
Jan 7, 2011
5,884
You don’t need to torque these screws very much…I would not use a torque wrench. Snug them up tight. You may need to retighten then after the butyl tape squeezes out some.
If you are using a drill/driver, yes, I would back off the torque setting some. You don’t want to strip out the aluminum plate.
And as @Parsons said, use some Tef Gel or similar stuff to protect against issues with dissimilar metals.
Give it a try on one, gain some confidence, then go for it !
Greg
