Hi Tim,
After some test cutting/fitting, I'm ready to start on the T&H Plywood. I noticed on your project website and previous posts that you recommend coating with Epoxy prior to cutting. From one of your previous posts:
"You do not need to thin it. That will just require more coats. I used West System at full strength and coated the entire sheet of plywood before cutting. This also helps to minimize splintering when cutting."
I haven't worked with epoxy before and don't want to screw this up. Looking at the West System website, I believe I need the 105 resin and 207 hardener. Is this the combination you used?
Also, was the thickness of the epoxy negligible relative to the final fit or did you accommodate by subtracting 1/32", 1/16", etc?
Great job by the way. I'm using my router as you've suggested and I'm impressed with the finished edge and accuracy of the cut. Boulter's about 20 minutes from home, so I'll be getting the plywood from them.
Thanks Tim,
Joe
Thanks Tim,
Joe
