My tiller had a pin on the top for the socket at the end of the tillerpilot arm. Although the pin was at the proper location per the installation instruction, it was too high, so the tillerpilot angled upward to the tiller and never functioned as well as it should.As part of my tiller refinishing project, I cut the pin off, hoping to install a new one underneath the tiller using a bracket made by the manufacturer. The bracket arrived and it's totally unsuitable because of the curvature of the underside of the tiller. I'm now considering mounting either a stainless steel bracket or a one-inch thick hardwood block to the starboard side of the tiller. The new tiller pin can be mounted in either one. Any other ideas? Thanks in advance.PeterH23 "Raven"
