Me Too
I too have been considering this conversion for my 1978 H-27. I even have the pedestal, wheel and all the fixings. Mine are off an old Hunter and are made by Fanyman but they are in fine shape. I don't think that the actual instillation will be that difficult but I alos don't know where to out the traveler. I've considered 2 options. One is to put it on a riser on the cabin top forward of where my doger fits and change to mid boom sheeting. The second is to put a removable bridge for the traveler forward of the wheel forward of the cockpit locker lid. I'd make it removable so when I'm in port on on the hook I have more space in the cockpit. Most of the time I think I'd leave it in place. I think that this would be easier and would probably remain in place most of the time but I stumble on what hardware to use to make it removable. In either case the old traveler is junk and need to be replaced.A second issue, and a little more daunting to me is what to do with the rudder tube. You have to cut the tube (above the waterline)to accomidate the radial quadrant. On top of the cut tube you glass a stuffing box. The problem is that the tube is now the tube is supported at the bottom (next to the hull) by fiber glass fillets and putty and at the top (next to the deck) in the same manner. When you cut the tube do you have to provide a new support structure for the top of the tube (next to the stuffing box)? I'm not convinced that the filleting at the base of the tube is strong enough. I'd hate to have it break and sink my old Hunter. Third, I think you need to reinforce the floor under the pedestal. I don't think that this is very difficult. I've read that you make an epoxy mix like peanut butter to kind of glue a 3/4" marine plywood board to the underside of the cockpit floor. Forth, you'd need to make some kind of pilot seat on top of the old beer cooler box that I have behind the existing traveler. You need to cut down the rudder shaft. I'd probably put a bolt through it an rig some kint of emergency tiller. I'd also consider adding a new shaft bearing on the top to limit the play of the shaft and reduce any possible pressure on the tube under the deck. What is there is a little loose. This is the one part I don't have but I think that Edson has what would be needed.I'm pretty good with wood work for the seat but I have to admit that I have very little expereince with fiberglass/epoxy so it kind of scares me.I'm on Long Island, NY (Nelsonhow@netscape.net) and would be appy to e-mail you more of the detials I've considered if you'd like. Howard Nelson
