Tiller Stay Line Replacement
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
For my Hunter 26, I have a "Tiller Stay" rudder control system. This is not the Davis Tiller Tamer. The Tiller Stay uses a stainless steel spring and friction spools that provides variable tension on yacht braid lines going to the tiller. This system works extremely well, except after 8 years, the line has broken and needs replacement. In my haste to get a replacement, I simply cut the old line away from the stainless steel spring without studying it closely to see how it was attached. If any of you that have a Tiller Stay know how the line is attached to the spring, I sure would appreciate your help. The challenge is to attach the line so it remains inside the center of the spring and not simply tied to the end of the spring. I've attempted to contact the manufacturer without any luck. Before I replace the system with the a another commercial system or any of the home-made systems, I would like to try repairing this one. Thanks, BrianW
Ross
Jun 15, 2004
14,693
The best I can suggest is that you play with this as a puzzle with some light line and try to figure it out. Is the spring loaded in tension or compression? Does the spring serve to keep the line taut? There are a limited number of ways this can be rigged and surely you can take your time and work it out.
