Tiller / rudderstock connection
Oct 31, 2019
4
Hi,I'm plannning to buy a Vega. I noticed on one I looked at that if I move the tiller sharply, it slips on the rudderstock. Is this easily fixed or could the shaft be worn out enough and have to do something major like replace the rudder?On some other Vegas I have seen, they have new rudders, one a spade, the other transom hung. It seems advantage of transom is better steering, especially in reverse, but presumably there are disadvantages to this too or Albin would have done it to start with. I'm wary about buying one of these when I don't know how well it was built really.Thanks,River
n4lbl
Oct 7, 2008
307
If you separate the rudder from the keel it becomes harder to keep it from being fragile.Alan
Gazuum
Oct 23, 2010
67
Pearson P365K Port Angeles
River,
Search the group for rudder repair and go from there.
As for adding another rudder, you will basically be converting
a big water boat to a coastal cruiser. Rudder location plays a
large part on whether a boat tends to broach with following seas
or surf happily as a stock AV will. A large price to pay for a
little more control motoring in reverse.
As for gelcoat cracks and wear, these boats are getting a
little long in the tooth and are showing their age as to be
expected.
Gordon
On 7/22/2016 1:38 PM,
ymail@... [AlbinVega] wrote:
Feb 13, 2010
528
I just bought one last week, as my first sailboat. I've read the rudder is a weak link, but as to the strength and ruggedness, I will take the blue water Vega, and fix the rudder problem, and learn to favor it maybe. I am a complete rookie however, but i'm happy with the sailing and the strength of the Vega.
Jan 28, 2001
694
Vegas are a very well built boat but several off them have developed problems with the rudder. I had to repair mine after I ran aground and a well meaning crew member said I'll work us off. He moved the tiller back and forth and broke the weld between the
shaft and the tab attached to it.
Aa far as a major repair goes it wasn't that difficult if you are mechanically inclined. I'd rate it as a minor major repair. It does detract from value of the boat and you should get it cheaper because of that. Figure on three to five days to do the repair.
I'm assuming the boat is currently out of the water. WaltFrom: AlbinVega@yahoogroups.com AlbinVega@yahoogroups.com on behalf of n4lbl alan.schulman@... [AlbinVega] AlbinVega@yahoogroups.com
Sent: Friday, July 22, 2016 11:44 PM
To: AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] Tiller / rudderstock connection
AlanOn Fri, Jul 22, 2016 at 1:38 PM,
ymail@... [AlbinVega] AlbinVega@yahoogroups.com wrote:
Jan 28, 2001
694
Re-reading the message I have to ask if the tiller is slipping on the shaft where it connects. If so it sound it just needs to have the tapered pin replaced. This is a minor repair. WaltFrom: AlbinVega@yahoogroups.com AlbinVega@yahoogroups.com on behalf of ymail@... [AlbinVega] AlbinVega@yahoogroups.com
Sent: Friday, July 22, 2016 7:38 PM
Subject: [AlbinVega] Tiller / rudderstock connection
River
May 30, 2006
1,075
River, you meant "two" rudders and not a "new" rudder?Some people have added a rudder aft of prop. "n4lbl alan.schulman@... [AlbinVega]" AlbinVega@yahoogroups.com wrote:
Jul 18, 2014
55
About tween rudder layout. I am one who install help-rudder behind propeller.Here is what everybody has to know before make decision:1. Help rudder Arend Schram was installed on tens Vega.2. Vega with help rudder has better steering under the sail especial with tacking, and significant steering improvement under the power forward and backward.3. You have to use proper size and material for help rudder installation, to keep you boat strong and prevent fragile. All system create straitened hull at additional rudder installation place. 4. The best effect you can expect with 3 blade propeller and without combi. With two blade propeller combi equipped I move backward predictable, but not I expected. With 3 blade propeller Vega move under power and under the sail like car.5. It two full day job but it required some skill, and experiences if you want to have reliable and strong both boat and steering system 6. About blue-water capability, honestly it 50%/50% for boat and skipper. If Skipper not experienced and make wrong decision mother nature will not forgive them, does not meter how strong boat he has, but good skipper, move weaker boat everywhere.So I am installed help rudder and I am happy. For today did not hear any compliance's or accidents from people who has Vega equipped with help rudder.
Feb 13, 2010
528
Much thanks Jon, your note was very encouraging and your instruction is very very helpful. I just bought my first sailboat a month ago, ( Vega 1625) and havent even had it hauled out of the water yet. There is a bit of play in the tiller, so I try to be gentle. Your note is very reassuring, thanks.....Craig
Jan 28, 2001
694
"Where creativity is king." Jon so very well said! WaltFrom: AlbinVega@yahoogroups.com AlbinVega@yahoogroups.com on behalf of craig hanson a62craig@... [AlbinVega] AlbinVega@yahoogroups.com
Sent: Saturday, July 30, 2016 11:27 AM
On Jul 29, 2016 9:39 PM, "Jon Phillips
jonphillipsmsw@... [AlbinVega]" AlbinVega@yahoogroups.com wrote:
