Tiller-rudder connection
Oct 2, 2005
465
If I recall, the tapered pin is cut off close to the rudder head at both ends. It would be difficult, at least for me, to determine in advance the diameter of the pin at the cuts. Length is then not the only issue.
Craig Tern V1519
Apr 30, 2000
197
Pin just needs to be width of tiller head as long as small end and big end seat flush. Your machinist is right - much easier to make a short pin using just the compound of the lathe. A longer pin might require offsetting the tailstock and machining between centers. Just for reference, US standard taper pins are 1/4" per foot (1/48) while metric pins are 1/50. You should be able to pick up a plain steel taper pin at a good hardware store (my local Ace hardware has them for about a dollar), test fit it and mark it for length, and have your machinist make it in stainless. Not sure how your local hardware stores operate in the UK but this is a cheap way to make sure you're right. Easy job to make one of these pins, even for an amateur machinist like me. Bill Bach V1071
Oct 19, 2019
921
Albin Vega 27 Limerick
Thanks Bill. I don't live in the UK but good advice.
All the best.
John V1447 Breakaway
John Kinsella
Mathematics and Statistics Dept
University of Limerick
Phone 0035361202148
Web jkcray.maths.ul.ie
Oct 19, 2019
921
No problem. :)John. V1447 Breakaway
John Kinsella
Phone 0035361202148
Oct 19, 2019
921
Ordered 4 from Grainger - hope they don't cancel as McMaster Carr did.
Thanks for info/advice.
Oct 19, 2019
921
Granger only deal business-to-business.
I'll see whether a local supplier can order from Granger on my behalf.
John
John Kinsella
Phone 0035361202148
Oct 30, 2019
574
Hi John,
Try MSC Direct at www1(dot)mscdirect(dot)com
I've used them in the past with good results. Do a search on their website for tapered pin.
Hope that helps.
Jack
Bella - V2620
Feb 12, 2008
337
Direct email is fine.
Do you know the part number or some other id number for the pin you would like?
Common parts come to the Boulder store in a day or two, if they have to order it in, it could be a week or so. -Tim
Oct 19, 2019
921
Hi.
The McMaster Carr part/stock number is: 90681A293
See below for spec.
Two would be great, four even better but whatever makes posting easier
for you is fine.
Maybe email me offlist to tell me what I owe you?
Happy to pay in advance - I could just letter post you $10/$20 or
whatever in cash money?
Thanks
John
Spec:
Material Type
Stainless Steel
Finish
Plain
Stainless Steel Type
18-8 Stainless Steel
Pin Type
Taper Pins
Taper Pin Type
Standard
System of Measurement
Inch
Small End Diameter
.167"
Large End Diameter
#4 (.250")
Large End Diameter Tolerance
-.0007"-+.0013"
Overall Length
4"
Length Tolerance
±.010"
Single Shear Strength
54,000 PSI
Rockwell Hardness
B95
Installation Instructions
To install, drive pins into tapered holes.
Specifications Met
American National Standards Institute (ANSI), American Society of
Mechanical Engineers (ASME)
ANSI Specification
ANSI B18.8.2
ASME Specification
ASME B18.8.2
Note
Pins have a uniform 1/4" per foot taper that runs the full length of
the pin.
Oct 31, 2019
303
I archive many of my old emails that I think I might want to read again.
Here is the old email chain with pin discussion.
