What are you looking for?
A tiller gives the clearest feedback and fastest response to the helmsman/woman. It also costs less, looks good, and swings up to clear the whole cockpit at anchor, or at the dock. Finally, its simple, reliable and low maintenance compared to a wheel. It's practical on boats around 30 feet or less, so it is the most common solution for these boats."considerable pressure on the tiller when close hauled" is called "weather helm." There are some good recent discussions in the archives on the causes and solutions of weather helm. Old, blown out sails are the most common cause, followed by the way the rig is set up, tuned, and sailed. Using the increased mechanical advantage of a wheel to solve a problem with weather helm means that the rudder will always be braking the boat. And heel and probability of broaching will also be higher than necessary. I would not see weather helm as a reason to have a wheel - it should be reduced by properly balancing the sailplan with the boat.Why a wheel, then? For larger boats, the size of the rudder makes the increased mechanical advantage a necessity, at the cost of feel and quickness. On medium sized boats, 25 to 30 feet, the reasons also include liking the look of a wheel, a special need for the mechanical advantage, and elimination of the tiller movement back and forth across the cockpit. (Somehow, this is not a problem on our h27, but we do have to sort out how crew and passengers can get by the tiller when coming about, etc.) So some medium sized boats have a wheel. It's your choice, but I don't recommend using a wheel to correct weather helm.DavidLady Lillie
